Reply
New Contributor
Digital Photo Professional 4.11 Can't Convert and Save
I am using DPP 4.11 and trying to convert and save a RAW file to a JPG file.  The software doesn't seem to work. the pop-up window apears, I press save and pop-up window goes away but no file is saved.
I am using MacOS Catalina 10.15.
When I save the RAW file with edits. opening the file in Preview or Photos in the MacOS i only see the orginal RAW file and not the edits. only see the edits in DPP
AndyP
Honored Contributor
Re: Digital Photo Professional 4.11 Can't Convert and Save
Seems to be  a  reported problem with Catalina. Try using Batch Process instead; I have seen where that works.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Esteemed Contributor
In windows I've seen this happen when you try to save the converted files to the same directory as the original.  Are you selecting a differnt save to folder for converted .JPGs?
~6D2(v1.1.0) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100 ~ImageClass MF644Cdw ~LBP622dw
New Contributor
Thanks the Batch Process worked.  Even to the same folder.
VIP
The output from DPP is usually a JPEG file.  DPP will not overwrite JPEG files under any circumstance.  It does not give you an error message, it just simply skips executing the task.  If you are editing JPEGs, then you must save the output to another folder.  I use a sub-folder, which is easily selected when using the Batch Process.
New Contributor
Must be big in the DPP for concert and save. It would not do for RAW file to JPG file in same or different directory. Only Batch save worked. Batch would give you an error message if you tried to batch save a jpg to same distort with same name.
Honored Contributor
Yes, apparently it is an incompatibiity with Catalina.
VIP
It is no bug.  Every version of DPP will not overwrite a JPEG file, either Windows or macOS.  It seems to be by design.
Honored Contributor
The bug relates to Convert & Save not functioning properly in Catalina. It is reported else where on the internet.
Honored Contributor
Canon issued DPP 4.11.1
powered by Lithium
