07-24-2019 09:46 AM
I am running DPP v4.7.21.0 on Windows 10. I also run Photoshop Elements 2019. I have imported RAW images to DPP but when I try the Transfer to Photoshop menu item in DPP I get an error message 'Failed to start Photoshop'. Is there anything I can do to remedy this?
07-25-2019 05:11 PM - edited 07-27-2019 12:53 PM
Photoshop Elements is not the same as Photoshop. The DPP transfer to Photoshop function does not work with Elements.
You can can use the Batch Transfer function and select Elements as the target.
07-24-2019 10:16 AM
Try a repair install of Photoshop Elements. Sounds like DPP doesn't think its installed.
07-24-2019 01:25 PM
Hi there. Thanks for the advice. How do I do the repair install?
07-24-2019 10:26 PM - edited 07-26-2019 09:37 AM
Start Menu > Control Panel > Programs and Features
Select Adobe Photoshop Elements in the list
Then change or repair (near top of applet).
If these options are not present, uninstall, restart the machine and reinstalll the program. Make sure you have the installer, or media and the products serial number if a uninstall and reinstall is required.
Now retest opening PSE from DPP.
07-27-2019 10:24 AM
Why not just start in PSE? DPP doesn't know what PSE is, it knows Photoshop.
07-27-2019 12:36 PM - edited 07-27-2019 12:39 PM
@ebiggs1 wrote:Why not just start in PSE? DPP doesn't know what PSE is, it knows Photoshop.
Because PSE comes with a crippled version of Adobe Camera Raw. No lens correction. All it does is convert file formats. Since Adobe began their subscription model PSE was crippled and has become a total waste of money. GIMP is more capable than PSE. I would not recommend PSE to anyone.
07-27-2019 12:47 PM
"I would not recommend PSE to anyone."
That's fine but it is just your opinion for whatever you think its worth. I do recommend PSE as it is the best amateur editor available. Lens correction may be a deal breaker for a pro or advanced amateur but not for the vast majority of people. As a complete post editor DPP is not ready for prime time. Canon seems satified to keep it at that level.
07-27-2019 05:57 PM
@ebiggs1 wrote:"I would not recommend PSE to anyone."
Obviously, you have not used PSE since Adobe began the subscription business model. They crippled it. Removed features.
07-27-2019 07:13 PM
