Reply
New Contributor
DPP 4.9.20 Convert and Save is not working
When trying to Convert and Save from RAW to JPG, after clicking on the Save button, it shows it's doing something for a couple of seconds but then no file appears.
I see this issue has appeared in previous versions of the software.
Is there a solution?
Regards
J Couto
Valued Contributor
Re: DPP 4.9.20 Convert and Save is not working
I've never had this problem but I don't use the save button, I always use "convert & save " on the "file" menu.
New Contributor
This is what I am doing "'convert and save"'.
Honored Contributor
You mean this screen shows up but you can't find the image in the destination shown in the popup?
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472, LRCC Classic
VIP
I have not used DPP often over the past few years.  I think the last version I used a lot was version 3 something.  As I recall, though, DPP did not like to overwrite existing files.  It did not prompt you, or give you choice or chance to rename the your new file.  DPP would just simply stop the processing, and never tell you that it stopped, nor why.
Valued Contributor
[ Edited ]
@JoseCouto wrote:
I have the same version of DPP and have experienced no issues saving to jpg. I don't use the file menu option, though. After I make my edits to the CR2, I select the SAVE button on the main screen, and then select the file type as jpg.
EDIT: OK, I just did another test using the "Convert and save..." off the file menu, and it too worked fine. Maybe you could download the software again and try anew.
Valued Contributor
It overwrites files now. And it asks your permission first.
New Contributor
Hi John,
This image does not appear. Once I enter the name of the file, I get the little busy circle for a couple of seconds and then goes back to the main screen.
New Contributor
Hi, I did try to save as well and with a different name and get the same result. I will try to redownload and reinstall.
powered by Lithium
