04-17-2019 03:44 PM
About to ugprade my older Canon T2i and looking at a few models and just now learning about the Canon Connect App. My question relates to Geotagging.
Granted I have ZERO experince with geotagging so forgive me if I ask or phrase this in a stupid way.
If the app is running and linked to my camera will it automatically geotag each photo as I take them? For instance if I have the phone in my pocket and walking around each time I take a picture will it capture the gps location and embeded it into the EXIF data?
Basically what I am a bit unclear on is how they two are linked?
Or
This is not critical I am just going on a vacation in Europe and would like to be able to auto geotag my pictures and if the app can do what I hope it does I will most likly go with a cheaper model. If it does not do what I want I will probably get a model with a built in GPS received like the 6D Mark II
04-18-2019 09:46 AM - edited 04-18-2019 09:49 AM
I'll have to reply again when I have more time. I took my 6D2 to Russia in Sept of 2017. 17 day trip traveling from St Petersburg to Moscow. 700 miles by boat. I used the GPS built into the camera. Worked well, had no problem acquiring a GPS signal. Have had the camera to Europe 3 times. England, Holland, France, Germany, Switzerland, Italy, etc. Worked great.
Camera or App - Wil be one or the other. If the camera is GPS capable, this will be embedded into EXIF data. If you are using the App, data from its GPS will be Embedded. They don't "share" or compare. Its one or the other. So if your phone can't get a good GPS signal and determine your location, you may not get the geo-tagging. My vote is stick with the camera.
~R5 C (1.0.6.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It04-18-2019 09:46 AM - edited 04-18-2019 09:49 AM
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It04-19-2019 09:56 AM
Thanks for the info and based on this it sounds like I will be getting the 6D Mark ii.
04-19-2019 11:58 AM
04-19-2019 09:58 PM - edited 04-19-2019 10:30 PM
I didn't make any changes to the default GPS settings on the camera. I have my GPS set to run only when the camera is turned on (mode 2). There is another option (mode 1) that periodically turns the GPS on even when the camera is off.
Regarding needing to have GPS on the camera turned on when using the EOS utiity to transfer. I didn't do this. I took the card out of the camera at the end of the day and pulled the images off the card using a built in card reader.
Geo-Tagging is present without the camera.
Looking at my manual, I see the GPS Logging feature. This is the one that captures your routes. I don't think I have this enabled. My android phone tracks my every move.
Thanks Wadizzle. Didn't know the camera did this.
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It04-20-2019 12:13 AM
I did purchase my 6D Mark II today, and have been playing with it. I just saw both of the last 2 messages and can confirm what shadowsports said. I pulled the card and put it in my laptop, openned the memory card and checked a few pictures I had snapped and in the properties of each file they had a Lat, Long, and Altitude for each picture. I did nothing other than take the picture and pull the card. No post processing and I had the GPS log function turned off. GPS was also in Mode 2
On that note I will add I did also transfer a picture to my phone using the Canon Connect app and it was able to show it had GPS data but I assumed that was because I was using the app to directly pull it off the camera. I then told the app to actuall downloaded the image to my phone storage. I then uploaded the to Google Photos and..... no GPS data so at first I was sure what Wadizzle said was correct but it must just be certain programs can not extract that data.
04-20-2019 12:08 PM - edited 04-20-2019 12:13 PM
Page 228 explains the route data option. Believe you have to use the Maps Utility in EOS to view. I've never tried in Google Photos. Also wanted to add, my battery life has been great. I shoot a mix of live view and viewfinder and get several hours of shots on a single battery. So for me, the GPS has been a cool feature for my basic needs.
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It04-20-2019 02:53 PM
I'm getting geo-tagging in Google Photos too. Not sure why you aren't.
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It08-24-2021 08:49 PM
I get geotag by reading the card in a PC/MAC.
With Canon Connect app via wifi geotag does not get sent.
Any ideas?
04-21-2019 04:15 AM - edited 04-21-2019 04:16 AM
@shadowsports wrote:I didn't make any changes to the default GPS settings on the camera. I have my GPS set to run only when the camera is turned on (mode 2). There is another option (mode 1) that periodically turns the GPS on even when the camera is off.
[deleted photo]
You’re welcome! I think automatically adding GPS coordinates to the EXIF could be a change in behavior from the 6D. I would have to check it out and see.
I have always had to turn on [GPS Logging} in the 6D because without it your EXIF would not contain GPS data. In addition, like I pointed out earlier, you had to have GPS turned on during EOSU transfers to see any GPS data in the EXIF.
Because of the huge current draw, I would keep GPS turned off. If I was at one location for a couple of hours, taking in dozens or hundreds of shots, why waste battery power when the GPS coordinates would all be pretty much the same, anyway. I could take a few GPS sampled photos, and then turn the GPS off. In post, I would copy and then write the GPS data to all the keeper images.
Running GPS all day while taking several hundred photos was always a recipe for a dead battery before the day was done.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
