12-24-2018 02:36 PM
I've always used Canon's DPP software to edit RAW images however, when my DPP4 software that I had installed for my 80D didn't work, I downloaded the lastest DPP4 software and installed it. It won't work on my Win 7 computer without installing Net Framework 4.7.2 software from Microsoft. I downloaded that software but it won't install. If I can't edit the RAW files I can't use my 6D II. Any ideas?
12-24-2018 04:34 PM
@grafxman wrote:I've always used Canon's DPP software to edit RAW images however, when my DPP4 software that I had installed for my 80D didn't work, I downloaded the lastest DPP4 software and installed it. It won't work on my Win 7 computer without installing Net Framework 4.7.2 software from Microsoft. I downloaded that software but it won't install. If I can't edit the RAW files I can't use my 6D II. Any ideas?
If you cannot install .NET, then you could be out of luck. You need to find out why your computer cannot run .NET 4.7.2.
https://docs.microsoft.com/en-us/dotnet/framework/get-started/system-requirements
You need to be able to install .NET 4.5 before you can install 4.7.2.
I think you should upgrade your computer to Windows 10, with a separate NVidia graphics card.
12-25-2018 10:00 AM
This is a MS issue not a Canon so call MS 1 (800) 642-7676
