06-12-2013 08:30 PM
No problem for 6d. Using Mac 10.8.3 and latest EOS Utility. Will not work with PS, LR or Image Capture. No problem for 6d. Tried for 6 hours before giving up.
06-12-2013 08:52 PM
Have you tried updating your Adobe Camera Raw plug in?
06-12-2013 09:00 PM
I'm using the latest release. I had tried the beta but had to delete it and go back to the last release. I had issues with the beta.
06-12-2013 09:11 PM
I'm not familiar with Macs but something sounds wrong on your end because the 5D3 has been on the market long enough for everyones software to be revamped to recognize it.
06-12-2013 09:43 PM
I agree with you. I think the camera is some how defective. I cannot find any logical reason why it wouldn't work.
06-12-2013 09:48 PM
Are you trying to download via a cable to the camera or by using a card reader? Can you do a file search on your computer using the file names from your jpg's but with a CR2 extension instead of .jpg?
06-12-2013 10:29 PM
If using a cable try pulling card out and using card reader, if the Mac can't see card then your card may be corrupted and your Mac just is not seeing the 5d3.
06-13-2013 09:44 AM
Yes, I am using a cable. I do not have a card reader. I also have a 6d. Pictures taken with the 6d can be downloaded from cards in either camera. Pictures taken with the 5d Mark 3 can not be dowloaded from either camera although they are viewable from both.
06-14-2013 06:13 PM
Replacement 5d Mark 3 body arrived less than a half hour ago. Up and running without issues. Downloading images with EOS utility. Nothing has been changed. Same SD card, everything is the same except for the body replacement.
Based on your comments, I have purchased a card reader. Thanks again.
06-14-2013 08:21 PM
That's a surprise. I don't understand why you couldn't download 5D3 files) from the 6D seeing that the camera recognized them.
