11-21-2019 03:00 AM
12-24-2021 06:12 AM
I’m having the exact same problem. How did you fix it?
01-19-2024 10:29 AM
Hi Kwinten,
this is a "feature" of the Camera Connect app, that seems to have a builtin limitation of 10.000 pictures. I ran into the same problem from one day to the other and tried everything, different Android devoices, resetting WiFi, re-installing the app and upgrading the firmware. Finally, using a fresh SD card solved the problem and after reducing the number of pictures below above threshold, the old SD card also was recognized as well. Unfortunately, there is almost no documentation on this app available.
