10-23-2016 05:42 PM
How does one shut off the auto-sensing of negatives on the canoscan 5600F? I should be able to preview the smaller 110 format and just crop around the smaller frames yet I cant even get to the preview window without the error that the film can't be detected.
10-25-2016 10:18 AM
Hi sverny,
Scanning 110 film is not supported with the CanoScan 5600F. You can try scanning with Thumbnail View turned off, but there is no guarantee that this will work:
1. Open the MP Navigator EX program.
2. Point to Scan/Import and click Film.
3. Select the Use the scanner driver checkbox, then click Open Scanner Driver.
4. Click Advanced Mode.
5. Next to Select Source, choose Film.
6. Click the Thumbnail button in the upper left hand corner of ScanGear to disable this view.
7. Click Preview.
8. Manually crop the images.
9. Click Scan.
10-25-2016 10:18 AM
Hi sverny,
7. Click Preview.
9. Click Scan.
10-26-2016 02:00 AM
03-04-2025 02:20 PM
It was the best. I find many many 110 negative and by this way many memories lived for me.
Thanks so much
