03-15-2022 08:09 AM - last edited on 01-28-2024 03:23 PM by Kristoff
Hi there,
I recently bought the Canon LiDE 400 scanner as the resolution goes up to 4800. I need the maximum resolution as I want to blow up some antique hand painted artworks which are tiny. I have tried downloading the IJ scan utility software and changing the settings in drivers to allow large image scanning (found this in a previous post) but the resolution is still fixed at 600dpi. I am on a macbook pro. Is there another way and why can i not scan at the full resolution?
Thanks
05-15-2024 10:12 AM
I was surprised I had this ability on my laser printer which only officially supports 1200 DPI maximum. I have no need for scans this large however.
~R5 C (1.0.9.1), ~R50v ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
05-16-2024 12:51 AM
yes, i checked it.
05-16-2024 12:54 AM
05-18-2024 10:56 AM - edited 05-18-2024 11:02 AM
Additional tests show that the vertical stripes are also clearly visible at 2400dpi:
And slightly visible at 1200dpi:
A quick look showed that around 600dpi it's not high res enough any more to notice them straight away.
Looks like the LiDE400 scaner has multiple significant problems with high dpi scans. Does anybody else see those stripes on their LiDE400 scans?
05-19-2024 02:00 PM
you need to lower the output resolution to 170mm x 233 mm. the input can be the full size of the paper (as long as it fits on the glass). but the output maxes at 6.7"x9.2"
05-19-2024 02:01 PM
the input can be the full glass. the output maxes at 6.7" x 9.2" at 4800dpi
05-20-2024 07:02 PM - edited 05-20-2024 07:24 PM
Did you just calculate how much pixel data fits into 4GB RAM when not using 48bit color mode and then express that as square inches times dots(pixels) per inch? 6.7 × 9.2 × 4800² * 24/8 = 4260556800 Byte ~= 3.96GB. Or Is that some kind of default preset size that the scanner software lets us select? Not sure what that your comment is supposed to mean or how this should be helpful.
Fact is: With the current driver on Windows 11 it is not possible to scan the full glass surface at 4800dpi in one go even with the ScanGear dialog.
05-20-2024 07:04 PM
No, I kept adjusting the size until it worked. If you don't find it helpful, then do whatever you like. I'm just trying to help.
05-23-2024 03:36 PM - edited 05-23-2024 03:40 PM
Presumably the Canon moderators deleted both our followup discussion and the useful discussion about the 3rd party tool working.
"The message you are trying to access is permanently deleted."
I can't see the posts any more. I don't want to post it again, maybe discussion of 3rd party software is not allowed here. Just adding a note that roughly 5 followup posts have disappeared.
Thanks to onlysublime, shadowsports, kvbarkley and co, who had contributed with the now deleted comments.
05-23-2024 04:04 PM
My original comment about Vuescan is still there. The problem is including links.
