02-22-2022 09:49 AM
1) Canon app download from ij.startcom fails to download app.
2) USB cable not compatible with Surface Pro X USB port.
Need help obtaining correct USB cable for my computer
Need help with Canon App, driver down load.
Thanks,
02-22-2022 10:57 AM
Hello!
So that the Community can help you better, we will need to know about any error messages you're seeing, and the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your device (USB or WiFi).
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
02-22-2022 11:49 AM
My computer is a Surface Pro X, Windows 10, WiFi connected, with no CD:ROM and no USB-Gen1 plug port. When following the Installation Instructions, Step 3, Part A, Online Setup, using ij.start.cannon and after clicking Download, the application does not run and a message appears that says drivers did not download and circles me back to startup download screen.
03-02-2022 12:43 PM
Hi LodesM1,
The Surface Pro X has USB Type C ports. The scanner must be connected to the computer that has a USB Type A port. There are USB C to A adapters available which should resolve this issue.
Before connecting your CanoScan LiDE 400 to that adapter and then to your Surface Pro, please download and install the driver from the Support Page of your CanoScan LiDE 400. The file that you should download and install is "CanoScan LiDE 400 Scanner Driver Ver.1.01 (Windows)" and it is available for download here:
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
