XA11 recording to SD card while using external monitor
dstevray
I need to be able to record on an SD card while simultaneously sending the signal out to an external monitor. Having read the manual (I am a newbie with the XA11), I cant find out how to do this or even if it is possible. Can anyone help?
Mark35mmF2
Hi there,
You should be able to output a signal through HDMI while simultaneaously recording to the SD card, I dont believe this can be done through USB though.
4 REPLIES 4
Mark35mmF2
Hi there,
Works as you suggest. Thanks.
Hi, I am having trouble with getting my laptop with windows 10 to recognize Xa11 camcorder. I followed all the how to, have the correct cables, including the video capture box for input. I down loaded OBS, tried adding it as a camera and nothing. do I need a driver or change something in my settings? Thank you for any advice.
Please start a new topic for this issue.  This is a 2-year topic you replied to for a different issue.
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
Avatar
