09-07-2016 12:29 PM
I use an external 7" monitor on my tripod to view live video while recording. I connect an HDMI cable from the camcorder to the monitor. However, HDMI also sends audio which then gets played back on the speakers of the external monitor and this audio then gets picked up again by the camcorder's microphone and I get that annoying squeel of audio feedback.
I have found that I can plug in audio earphones to the monitor to cut out the monitor's speakers but this is not convienient.
I want to record the audio so disabling the camera's microphone is not an option
Is there a way to mute the audio output of the HDMI cable?
09-19-2017 10:18 AM
I suggest you read the instructions. Having just looked at the user manual on the Viltrox website, you can turn the volume down in the menu settings. It is set at a default of 50%.
09-08-2016 10:07 AM
Yeah, try turning down, or OFF, the volume on the monitor.
09-08-2016 10:48 AM
09-15-2017 11:02 AM
Hi there.
I know that this is an old post, but i was wandering if you ever solved your problem.
And yes, i have the same problem to.
Very annoying.
I have also a 7'' external monitor for my camera, and i also need the sound.
I have tried 3 different HDMI cables, but i guess that they are not the problem.
If there is anyone who knows the sollution, than please tell me.
Kind regards, Joska.
09-18-2017 02:07 PM
Without a way of turning down or muting the monitor there is not a lot you can do.
09-19-2017 12:20 AM
Thanks for your reply.
The only way i can fix it is to place them 1 meter appart.
But that is not how i like to use it.
09-19-2017 10:18 AM
09-19-2017 10:53 AM
Thank you very much.
I didn't know that.
As there was no volume control button, i asumed that it had no sound at all.
Thanks again for taking the time to help me out here.
Much appreciated.
09-19-2017 11:13 AM - edited 09-19-2017 12:04 PM
@ IamintheUK.
Well done mate!
You 've nailed it and scored lots of kudo's from me.
I didn't even know half how good this little monitor is, but now i do!
There are many setting opportunities that may come in handy.
Now i am even more pleased with my Viltrox than i was before.
Thanks again.
09-19-2017 07:29 PM
You're very welcome.
