08-29-2022
01:12 PM
08:55 AM
Just got the R5C, and have my Rode Wireless GO II mic plugged in which works flawlessly with my R5. I made separate channels within the cinema menu, turned the internal mic all the way down. Channel 1 is clearly the RODE mic, but all my videos are still recording ONLY the internal mic. I have no idea how to fix this! Any ideas?
10-04-2022 12:28 PM
The latest firmware update—1.0.2.1—has fixed that problem, the internal mic can now be turned off.
08-29-2022 02:21 PM
Just figured something out, when set to XF-AVC, it was recording the internal mic and not my RODE. When I switched to MP4 4:2:2, it now records the RODE, and sees my settings of 0 for the inernal mic. I fixed it for now, but why doesn't that work with the XF-AVC codec?
08-29-2022 04:18 PM
The entire 'internal mic' issue has been troublesome from the get-go. Many of us, my self included, do not use MP4 for recording, and the inability to defeat the internal mic makes no sense whatsoever for a so-called professional video device. I typically shoot XF-AVC or RAW with an external mic, either a Rode NTG-5 attached to the Tascam adapter, or the Canon hot shoe mic. In this scenario, the internal mic records to channels 3&4 and I delete those tracks in post, but it is a nuisance. Numerous complaints to Canon have apparently ended up in file 13—the trash can—since there has been no mention of an eventual fix for that problem. It appears that the R5c's internal software is stuck in the consumer realm.
08-29-2022 04:27 PM
Why do you not use MP4? Is XF-AVC superior in some way to 4:2:2 CLOG 3?
08-29-2022 04:39 PM - edited 08-29-2022 04:40 PM
@johnnymc,
Many of us have brought this to light and requested the option (feature request) to disable channels 3&4 in the Cine Menu when using XF-AVC or RAW.
Please provide product feedback to Canon regarding this request. Hopefully if enough of us request it, it might make it into a future FW release.
Reach Us > +Feedback > Product
08-29-2022 04:39 PM
If you're shooting proxies and RAW the file names will be the same with XF-AVC, and I am not certain that MP4 offers all of the metadata that is available with XF-AVC. But the issue remains that the internal mic func should not be dependent upon which codec is being used. I also shoot with a C300 MK III and C500 and both cameras allow the internal mic to be turned off. It is my understanding that the R5c's video software had been taken from the C70, and it too allows the internal mic to be turned off.
08-30-2022 09:39 PM
totally agree!
10-04-2022 12:28 PM
10-07-2022 09:43 AM
Hi Ron,
Just returned from vacation and see I am late to the game. I should have figured you'd be all over 1.0.2.1.
Cheers!
10-07-2022 10:11 AM
Yes, and it does indeed work as we'd requested, but the grayed out menu items have not come to life.
