Canon C200 On Screen Display -- How to get a clean feed out?
JWEnnis
I have followed all the instructions to toggle through to the Monitor menu and select OFF for OSD (On Screen Display) but that still leaves STBY or REC on screen, which is shared on our SDI feed.
Any suggestions?
2 REPLIES 2
Hazel_T
Hi JWEnnis,
Turning off the OSD Output setting on the camera should be all you need to do for a clean HDMI or SDI output.
Just to double check is the issue that you are still seeing STBY and REC on the built in EOS C200 screen, or is it showing on your connected SDI monitor? If it is still showing on the built in EOS C200 monitor that is okay. The OSD Output setting only applies to the outputs HDMI and SDI outputs to an external monitor. That setting does not turn off the onscreen displays on the built in monitor.
Thank you! Unfortunately that is a bug with the C200 and SDI output, it wasn't made for a clean feed. I spent half an hour yesterday on the phone with a technician at Canon who was experimenting with a monitor on his end and he saw that as well. I'm hoping they can provide a fix. Thank you much for your time, Hazel!
03/28/2023: New firmware version 1.0.3.1 is available for EOS-R5 C
03/14/2023: New firmware version 1.8.1 is available for EOS R6
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.0
01/18/2023: New firmware version 1.1.1 is available for EOS R6 Mark II
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
