09-20-2024 02:40 PM - edited 09-21-2024 03:54 AM
I would really appreciate some guidance from community. Finally took the plunge and got the Pro - 300. My excitement has turned into frustration and tried to trouble shoot internet and manual for solution - unsuccessful.
Setup: Mac mini M2 with Pro 300 printer.
Printing issue.
Apologies for my ignorance or stupidity but despite searching manual, internet i am unable to resolve issue. Any guidance will be highly valued. I have reinstalled all drivers from canon USA, then from canon Europe and even Aus.
thanks in advance.
Morne
09-27-2024 03:48 PM
Hi
I honestly don't have an answer in relation to this, but I have some issues with matte paper as well.
I'm using windows 11 so definitely no help in Mac world.
What I can say is that I had been using a Pixma Pro-100 with great success printing 13x19 matte. Then the printer died.
When I decided on the Pro-300 I knew it used pigment inks instead of dye.
Pigment inks set very differently on matte paper.
It's could be that it's more of a straight photo paper printer and matte paper is not as pleasing with pigments.
One can't do borderless print on a 13x19 matte also which was my normal method.
In an attempt to overcome the situation I download Canons ICC profiles without success. Then I download a ICC profile for A-Sub paper, and will also look into a profile from Red River.
09-29-2024 03:24 AM
Hi there
I have been struggling with the same issue but I've found a solution, albeit with a compromise on margin size.
On your printer select manual feed and pro premium matte as paper. On your computer, using the Canon Print App select A3 (25 margin), NOT the basic A3 option. This is the compromise - you'll be stuck with a 25mm margin for your print. You should now be able to select Pro Premium Matte as your media type, set margins to 25mm and Pro Premium Matte in the profile tab. You can now change from auto to Pro Premium Matte in the profile and hit print.
That should work! I'm not a fan of 25mm margins but it seems to be the only option.
Good luck and get in touch if you still have problems.
Paul
09-30-2024 02:06 PM
Hi. Verify that the printer driver that is installed is actually the Canon IJ Series driver and not the Apple AirPrint driver.
