11-17-2024 06:34 AM - last edited on 11-17-2024 08:10 AM by James_C
Hello all.
After 3 years without using my pro 1000 I would like to use it again.. And i messed a little bit with the media configuration tool. I would like to reset my printer to factory default for the papers settings. Do you know how to do it please ?
Thanks a lot.
11-19-2024 01:34 PM
Hi Manuparis,
To reset your imagePROGRAF PRO-1000, please turn your printer on and follow these steps:
1. Press the HOME button one time.
2. Use the down arrow to select Various settings and press OK.
3. Device settings will be selected. Press OK.
4. Use the down arrow to select Reset setting and press OK.
5. Choose the desired setting and press OK. Your printer will be reset.
The reset settings are as follows:
Web service setup only - Sets the Web service settings back to the default.
LAN settings only - Sets the LAN settings other than the administrator password back to the default.
Settings only - Sets the settings such as the paper size or media type back to the default.
Device info sending setting only - Sets only the device information sending settings back to the default.
Reset all - Sets all settings you made to the printer back to the default. The administrator password is restored to the default setting as well.
