04-25-2021 06:26 AM
Hi all
Using the Pixma Pro 100s. Having issues with inaccurate colors and so need to ask a few questions rather than waste my entire fresh box of Hahnemuhle Baryta paper trying to work it out
So far I have been printing from from Canon Print Studio Pro in Photoshop, setting the paper profile in Photoshop before opening Print studio pro, then selecting no color management in PSP. this as far as I can see is the recommended method, but prints coming out with a blue cast.
I don't have an Eizo setup, working from a 2017 iMac
Can someone advise the proper/best method / settings to achieve accurate colors?
Is it better to print straight from Photoshop Ie. bypassing Print studio pro?
Do I need to use colorsync ?
many thanks
04-27-2021 05:36 AM
04-27-2021 07:02 AM
04-27-2021 07:08 AM
04-27-2021 07:09 AM
Infact, here is a link to the manual, just in-case you havent read it.
04-27-2021 07:11 AM
much appreciated will give this a try later
04-27-2021 07:38 AM
"Your room lighting will affect the resulting print. Try taking it outside and see how it looks."
That's great if one is going to display their prints outside. Otherwise you need to adjust settings to give the desired print output in the intended viewing conditions.
OP says that the OutbackPhoto test image is printing dark in his opinion. I see two possibilities: 1. OP prefers brighter images or 2. Printer is printing darker due to calibration tolerances. In either event that is why the printer driver or PSP provide the capability to adjust brightness and tone.
04-27-2021 08:10 AM
04-27-2021 08:30 AM
@xrischan wrote:
HI. Yes, i see the point of that . ICM management will however grantee the correct colours and brightness are achieved despite current room lighting and screen brightness. Will also guarantee transparency across printers. After working through my fleet i have found its best to get the printer settled then work back through the chain to the screen. I now have all printers printing what i see on screen.
I agree on a color managed workflow. I have a calibrated monitor on a Windows PC. OP is using a Mac; I have read that they are pretty good out of the box.
As you no doubt have discovered, the greatest problem with printing is having the monitor too bright. That is the good thing about using the OutbackPhoto (or other standardized test image). Get the print looking good and then adjust monitor to reflect how the print looks.
I calibrate my monitor to D50, 80 cd/m^2.
04-27-2021 11:14 AM - last edited on 04-27-2021 11:22 AM by Tiffany
I have just found this page for your paper;
<link removed per forum guidelines>
I dont know if the Pixma software bundle comes with Profile Editior software, but at least you can download an ICM made for your paper and your printer from their own website
04-27-2021 08:22 AM
Here is the PDF manual for Print Studio Pro.
https://ij.manual.canon/ij/webmanual/PrintStudioPro/M/1.2/EN/PSP/Top.html
See the info on the Pattern Print capability.
