Reply
New Contributor
Stranger Print - Pixma 100 PS 2018
[ Edited ]
I just got the printer, did the alignment and copied the plugin from 2017 to the 2018 folder.
This is my first print test, attached settings and photo of the print.(Photoshop CC 2018 with Canon Pro Plugin - firmware updated)
  1. the print was out within 15 seconds, i thought this should take some time (8.5X11)
  2. As you can see there is a print smudge at the bottom and green strips on the right, also the photo should have at least 20% more skys on the top, as Canon was so generous to give 5 papers, 1 is already garbage.
  3. the preview within the plugin canon pro should be "pixlated" is it a down sample, or just showing how it will look on luster, not sure.
Please advise,
Ethan
Honored Contributor
Re: Stranger Print - Pixma 100 PS 2018
While you are doing debugging just use regular printer paper and select Plain Paper option so you don't waste the photo paper.
What happens when you print a nozzle check from the Maintenance tab?
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
New Contributor
[ Edited ]
booth allign and nozzel looks good
photos are not, anyone?
Honored Contributor
Since it’s brand new can you take it back or do you have a Canon support line to call in your country?
New Contributor
The problem was the file size, apperantly i was sending the PSB (2GB) file.
Thanks for all trying to help
powered by Lithium
