07-28-2018 11:56 AM - edited 07-28-2018 12:05 PM
Hello,
I try to print something every six weeks or so to keep the ink from drying out. I am wondering if I actually need to print or is just turning on the printer enough to move the ink.
Thanks.
<edit> I am using a Canon Pro 10.
07-28-2018 01:42 PM
@nvw wrote:Hello,
Thanks.
You need to print something. Turing the printer on regularly helps, and while the "priming" that occurs will keep the printer in a ready state, the head could still become clogged at the nozzle unless a printout or calibration is performed.
07-28-2018 12:03 PM
Hi, nvw!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
07-28-2018 01:42 PM
@nvw wrote:Hello,
Thanks.
07-28-2018 01:45 PM
Got it, thanks.
