Our TM-300 has started randomly feeding and cutting paper from the roll with nothing printed. This seems to happen randomly and with an empty queue. It will feed multiple "sheets" and cut. We will come in some mornings and find 4 or 5 "sheets" hav...
I'm not sure if my problem is with LR or my Pixma Pro-100 printer. Below are 2 versions of the same photo. The bottom one is the original LR edited one and he top one is what the image looks like coming from my Canon printer. Color management is ...
I've had this printer for 9 years and have never run into this issue before...I can proof an image on 8x11, but then when I go to run it full size on the same roll material, the resulting image is blown out and nowhere near the same output of the 8x1...
Hi there, I have a Canon pixma pro-200 and am trying to test print some illustrations to check colors. I'm printing through Photoshop using a macstudio. When I try to print using Photoshop settings, it tells me to make sure to disable the printer's...
I have two Pixma Pro 100 printers. The first one started printing with the colors "off". I'd remove the printer and add it back and it would work for awhile, and then just completely quit printing accurately. Then, the 2nd printer did the same thing....
Pro 9000 Mark 2 prints same brown toned pics no matter how I manually set colors-what's up?
Hello. My Canon Pro 1000 didn’t finish printing. I can’t figure out why. Attaching a pic. Thank you for any suggestions.
I have Canon pro 1000. My MBK looks bad in nozzle check? What does it mean?
Greetings. New to professional printing... I've completed setup of my new Pro 300 printer and began my first test prints last night. I printed two photos on Canon SG-201 4x6" Semi-Gloss, and two sheets of Pro Luster LU-101 to produce a couple 8x12" p...
We just got a TC-20M printer at work and want to use it to print 24"x18" documents. We bought a 24" roll of paper and its printing beautifully but seems to cut the paper at 24" so it ends up being 24" x 24" instead of 24" x 18."Is there something we ...
I don't suppose anywhere here can urgently help! One of the ribbons inside my Canon Pixma Pro 200 has come loose and is causing the printer to throw up an error that a foreign object is inside the printer. I'll attach photos, does anyone know where t...
Hello everyone,i have canon pixma pro 100 s and i got this error message , I’ve already turned the printer off , I know that has a very small spring that allows it to bounce front to back during printing maybe that spring got damaged ? I don’t know w...
Is it true that it purges all the ink tanks, and that you have to buy a brand new set of inks, or does it just fill ut the new one and have a slight purge?If you have, what was the interval? 1 year, 2, 3?Any feedback welcome!
I am a painter and I make prints of my art and sell them. Ive just made the switch from an Epson P900 (feed problems) to the Pro 1000. I really like that paper, its affordable and nice, but it doesn't have any ICC profiles for anything but the Epson....
Subject | Author | Posted |
04-22-2024 03:38 PM | ||
04-17-2024 04:47 PM | ||
04-15-2024 05:25 AM | ||
04-14-2024 07:37 PM | ||
04-11-2024 01:54 PM |
