Prints are not centered - Canon Pixma Pro 100
orkusmg
I've read through similar posts here and for none of those fix was provided due to (apparently) lack of details - I wil try to describe issue best I can.
So - problem is simple. I do not want to print boarderless. I want boarders.
Every print, from 2 different computers (Win7 Pro 64bit and Windows 10 Pro 64bit - both with latest updates) is NOT centered.
When paper sits in printer tray (prior printing) the TOP BOARDER and after the print (if printed landscape orientated) makes it then RIGHT BOARDER is shorter (narrower) then the opposite one. Print is not centered.
Conditions of printing:
- I have latest drivers installed from internet (File Version 1.06)
- Problem seem to touch every software I print from: Excel, Photoshop CC 2018, Lightroom CC 2018, Lightroom Classic CC 2018, Canon Print Studio Pro (latest version just installed)
- Problem touches every print size: these I tried: 4"x6" (10x15cm - in reality 101.6mm x 152.4mm) and these from table below
A3+329 x 48313 x 19
A3297 × 42011.7 × 16.5
A4210 × 2978.3 × 11.7
- All prints are made exclusively on original Canon papers of various sizes of models listed below:
  • PT-101
  • PP-201
  • SG-201
  • MP-101
- For all prints I select corresponding with paper ICC profile, I've got callibrated monitor too. Nothing wrong with color or brightness, (for Photoshop I let photoshop manage the collors and I double check "Printer settings" options for orientation, color management, quality, paper size etc.)
- In all mentioned applications (except excell - being honest) I have used standard (included) print sizes listed above and ALSO I have created custom print sizes taken from exact measurements of paper, and I mean EXACT. In all cases prints are NOT centered.
- I have tested prints on both "Prevent paper abrasion" and "Detect paper width" options enabled/disabled in any combination. In every possible combination - prints are NOT centered.
- I have tested to print (using vaiety of above combination of papers/settings etc.) using both WS (8bit) and XPS (16bit) drivers and here results are: prints are NOT centered (on both)....
- I have created new prints from scratch (using Photoshop) heaving stndard AND measured dimensions of all above papers and used all possible combination of centering/scaling to fit etc options - In all cases prints are NOT centered.
Ok - I can not think of any other printing conditions from top of my head, if I missed something - please leat me know.
So dear Canon - are able to resolve problem that seems to be touching intermittently all Canon printers from PRO series?
26 REPLIES 26
Stephen
Moderator
Moderator
Hello, orkusmg!
Thanks for reaching out to Canon USA!
It sounds like you've done quite a bit of troubleshooting on your own, and we appreciate that! We suggest reaching out to support to ensure everything is setup properly and to do some additional troubleshooting to get to the bottom of this! Our team can be reached by phone at 1-800-OK-CANON (800-652-2666) weekdays from 10am to 10pm (ET).
If you're outside of the US, you'll want to reach out to Canon Support in your country/region. You'll find contact information by clicking HERE.
Ah right, so known problem with no solution - Thank you for your time Canon.
Did you call Canon?
Have you tried this workaround with Lightroom?
Doc
Epic!  Just testing this ouit, actually I was asking Jose to do vid about it! 🙂 Been busy last days so haven't seen he posted a video 😉 Thanks!
Still doesn't work, complette mess...
I have a Pro-100. Print via USB from a Windows 10 machine and via WiFi from macOS High Sierra machine. No problem with getting prints centered. So either a defective printer or some settings issue that maybe we can solve together.
the 1.06 file you mentioned is firmware version, not a driver. What OS are you using? If macOS are you using the IJ series version of the printer (not the Bonjour version)?
In either OS have you downloaed the laest driver from the Canon site?
Windows 10 Pro 64bit via USB
and
Win 7Pro 64bit via WiFi
Yes, I have latest drivers. It seems to me like h/w issue
Jose does have a video on it.  Did you check the video McNeese linked?
As I recall, the trick was to go into the page setup, select the option for borderless printing (which lets the margins go to 0) and then define the margin you really want to create the border.
Tim Campbell
5D III, 5D IV, 60Da
