07-18-2013 06:16 AM
My Print Studio Pro stopped working on all applications (PSE and LR). It opens OK, but the selected image does not show up nor does any of the selection values like paper size show. Only the headlines appear?
Thanks
07-18-2013 09:55 AM
Hi otava!
So that the Community can help you better, we will need to know exactly what equipment you're using, any error messages you're getting, and the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet). Any other details you'd like to give will only help the Community better understand your issue! Thanks and have a great day!
07-18-2013 02:41 PM
Sorry
OS: Windows 7, Home Premium, Service Pack 1.
PC: HP Pavilion g, ADM A4 vision, 6 Gb
Printer Canon Pro-100, USB connection
Photoshop Elements 10
Lighroom 4
The system has been workin OK but stopped suddenly. No error messages. The Print Studio Pro opens, but no image shows up as before.
07-24-2013 09:09 AM
And you have done the obvious reboot of the computer and printer? Turn the computer completely off and the printer also.
Turn on the computer and then the printer. If this doesn't fix it. Uninstall and re-install Print Studio Pro.
07-26-2013 04:59 AM
Thanks
Reloading does the following.
When clicking the Canon Print Studio Pro: "Print Studio Pro requires 1024 x 768 or higher displayresolution and high color display color depth."
After that the Studio Pro opens but the image to be printed does not show up or it just might flicker for a extremely short time and disappeares.
Thanks
07-26-2013 10:07 AM
Can you print form other WIndows programs? If you can than something went wrong with the PSP instalition. If nothing prints, try a new USB printer cable (must be rated for printing).
I noticed on the Canon web site there are pretty new drivers and software updates. You have checked recently to make sure you have the latest?
07-26-2013 04:08 PM
Thanks
I have now installed latest driver for Pro-100, reinstalled Canon Print Studio Pro from CD. I can print with my Lightroom 4 and PSE 10 using the normal print command but the Print Studio Pro does not work. I have also cleaned my registeres.
07-26-2013 05:38 PM - edited 07-26-2013 05:39 PM
Well at least that is progress!
Personally I would prefer LR to any of the Canon give away programs. I just bought LR5 but actually it isn't much different except they improved the brush somewhat.
But now we know, the printer is fine, the USB cable is OK, and your computer is doing it's job. There has to be something wrong with PSPro.
You did tell PSP, when you installed it, to install the plug-in in LR? You can check this in LR by selecting the Managing plug-ins drop down under the File tab. Check that next.
07-26-2013 05:56 PM
Maybe I should add:
From the [File] menu, navigate as follows:
Photoshop Elements:
Click [Automation Tools] - [Canon Print Studio Pro...].
Lightroom 4:
Click [Plug-in Extras] - [Canon Print Studio Pro...].
Print Studio Pro starts, and the image displayed in Photoshop Elements or Lightroom appears in
Print Studio Pro.
07-26-2013 07:41 PM
OK
They both show under the file > plug-in. The Aplication opens, but it is "empty". Unfortunately I cannot include a screen capture, but for example on the right hand panel only the headings appeare like "Printer" but there are no printers to seleckt. Empty like the other options as well. Just headings nothing to select.
I guess there is not much to do other than wait a new update. This program has worked. Thanks anyway.
BTW I was planing to purchare LR 5 just because of the brush, if it really is that good for cuting images.
Thanks
