11-01-2022 06:20 PM
Hi all, I installed Ventura on my M1 macbook pro, uploaded the latest Canon driver for my printer, and now I can't print correctly (unless via AirPrint, which I don't want)
I am seemingly able to install and select from the list the new CUPS driver, when I go to Lightroom I can see the driver, when I launch the settings dialog, the option to adjust printer settings isn't responsive. Can't change anything there, the "OK" button is enabled but doesn't actually do anything. I can only click "Cancel", and that causes Lightroom to immediately, and predictably crash every time.
Same with Photoshop, the only difference is the driver dialog doesn't crash Photoshop.
Any experiences?
Thanks
11-29-2022 03:39 PM
Well, I might have fixed the issue. I went into MacOS and manually deleted the driver and other Canon software. I ran three different test prints (color, b&w), and the results look promising. Moreover, the printer options are remaining consistent between prints (I used the same paper on all the test prints). I will continue to monitor the output to ensure I am getting accurate colors. Gratitude to all of you who offered solutions. They helped me narrow my search for possible solutions.
11-29-2022 05:05 PM
When you say you deleted the driver did you redownload and reinstall the driver?
11-29-2022 07:12 PM
Yep, I think the Canon support guy had me to pretty much the same.
