01-30-2020 12:47 PM
I just got a new Pro-100 and I'm trying to print on glossy card stock, and no matter what I change the stock type to the prints are soaking wet with ink and even when I let it dry it results in a blurry, splotchy mess.
01-30-2020 03:11 PM - edited 01-30-2020 03:12 PM
Is the card stock intended to be printed on with dye ink? Dye ink needs to be absorbed into the print layer.
Double check you are printing on the correct side. Print side faces out when paper is loaded.
02-02-2020 12:08 PM
02-26-2021 11:33 AM
I have that problem too. I'm not sure if it's not using the right type of photo paper? I tried two different brands (inkjet photo papers) and they came out wet smudgy prints. I've read somewhere that we have to stay with certain brands. True?
02-26-2021 11:35 AM
I like to add that I've set the settings to print on glossy paper, same result.
02-26-2021 11:41 AM
02-26-2021 12:32 PM
Yeah, I saw that. The photo paper I have has the brand logo printed on the backside.
02-26-2021 01:40 PM
Does the paper vendor recommend a media tyype? If not you could try Other Glossy Photo Paper and the others if that doesn't work.
12-29-2025 10:28 AM
I got exactly the same issue.
Pixma 3650,
Cleaned everything couple times
Try with mat paper (no contrast)
Try with glossy paper (2 brands) same results (work with an old pixma 15 years old)
Try to print mat setting on glossy, same result
Try to print shiny on glossy, same result...
Try to let Canon sync colors,
Try to let Canon grey grading print
SAME RESULT.
What could we do ? Thanks.
Gary
12-29-2025 10:49 AM
fixed it with the right paper face. It's now very convenient on this pixma, cause you think you are not puting the papier in the right side. But it is what it is.
