03-19-2023 10:19 AM
I'm hoping someone can help me. I have been consistently printing with my Canon Pro-1000 for almost 3 years now. I am experiencing the following issue with many of my prints:
Correct appearance
Magenta cast at top of print
I have run numerous cleaning cycles, deep cleaning cycles and even system cleaning. My nozzle checks were very hit and miss. Sometimes they'd come out fine, but it wouldn't take long for them to indicate issues again. I have even since replaced the printhead, but I was shocked to find the yellow colour still not coming through properly on the nozzle check. This didn't make any sense to me, because how could a brand new printhead be clogged prior to printing anything but the head alignment sheets?
Anyway, it only took one clean to fix this issue and I generally don't have any problems with my nozzle checks. However, the magenta cast is STILL appearing and even Canon's support seem absolutely baffled by this!
This is not a consistent issue and does not occur on every print. It also seems less likely to occur on a borderless print.
Would anyone have any idea as to what the issue could be that is causing this?
Any help is much appreciated.
03-20-2023 09:42 AM
I don't want to jinx it, but unidirectional printing seems to have done the trick. Makes me wonder if there's an issue with the head alignment and perhaps I should reset this again.
03-24-2023 08:51 AM
Unidirectional printing did not fix the issue after all.
I attempted head alignment twice but both failed and the printout definitely shows issues, particularly with the yellow.
So I did some more nozzle checks and there were clearly issues with the yellow here
I performed a cleaning cycle which improved the yellow drastically, but there were still some breakages in the grid. So finally I performed a deep cycle and this made matters worse, and now the yellow is looking terrible again.
Any ideas? Bearing in mind this issue is still occurring after replacing the printhead, so I honestly can't understand how there could be an issue with the yellow nozzle itself.
09-14-2023 06:35 AM
I have the same issue. Always at the end of the print, but also some mid-tones are lacking. It is clearly visible in B/W prints. Very frustrating. It happens regardless if I print over WLAN / LAN or USB.
06-07-2023 05:58 AM
Did you get to the bottom of the problem? I'm getting the exact same issue with the yellow casting in the at the top part of the print.
11-20-2023 11:41 AM
Same! Did you get tot he bottom of your issue? I can see it was not long ago.
Thanks
Bhavin UK
11-02-2023 09:33 AM
Just wondering if you ever found a solution to this issue? I'm having the same problem with the first couple of inches of some prints appearing to be missing the yellow ink. I replaced the print head (at huge expense!) and the problem was still there. It doesn't occur on every print just seems to be random. Weirdly and in desperation I tried rotating a problematic image 180º and printed again without any problems but this doesn't work every time, but suggests a software issue? So frustrating!
Nozzle checks show everything to be ok even directly after a bad print.
11-03-2023 01:59 PM
Hi danjmo,
Please print a nozzle check on plain paper. Once printed, please take a photo of that page and please insert it into a reply to this post.
To print this, please follow these steps:
1. Make sure that the power is turned on to your imagePROGRAF PRO-1000.
2. Load a sheet of A4 or Letter-sized plain paper in the rear tray.
3. After inserting the paper into the machine, the paper information registration screen is displayed on the touch screen. Select A4 or Letter for Page size and Plain paper for Type, then tap Register. If a message is displayed on the screen, follow the directions in the message to complete registration.
4. Holding both sides of the paper output tray, gently open it.
5. Extend the paper output support..
6. Use the down arrow to select Maintenance and press OK.
7. Select Print nozzle check pattern and press OK.
8. Select Yes and press OK.
11-06-2023 12:04 PM - edited 11-06-2023 12:05 PM
Hi Patrick, photos of my nozzle check attached. As you can see, no issues showing at all and this is usually the case when I print a check pattern immediately after a bad print too. The issue only occurs on some prints, and only for the first inch or two of a print, then the yellow kicks back in and the rest of print looks fine... often in the same batch of an identical image. New print head didn't solve the issue!
Any thoughts gratefully recieved as Canon support offered no help.
11-05-2023 03:56 PM - edited 11-05-2023 03:57 PM
This happens with a very light blue for me and it's seldom an issue. I'm printing on a Pro-2000 and 6100 but they all use the same print head. My solution has been to place the image 2" down to avoid the issue.
My conclusion is there is an issue with the platen vacuum and the first 2" doesn't allow for proper pressure. Since we're printing on rolls it hasn't been too much of an issue to regulate as needed but I could see this being problematic on a smaller printer whereas you're trying to print the exact size as the finished print. We have to trim all of our prints. I don't really have a fix, more of a workaround.
11-06-2023 12:00 PM
Hi Josh, thanks for the suggestion and glad you are able to find a workaround. Unfortunately I mainly print borderless A3/A2 so that's not an option in this case.
