10-03-2014 03:35 PM
I previously owned the Canon Pro 9500 II, loved it, colors matched my screen perfect. Prints from my photo lab also match monitor and Pro 9500 prints.
The print head died on me, so I decided to upgrade to the Pro 10 and now I'm completely frustrated. Tried printing some photos and the colors are different and much darker. Using the same paper and settings as before.
The bigger problem, I use my printer for graphics works too and the colors are not even close. A few of the designs look passable, but others are completey different. Colors look fine on my monitor and other devices and printed on the Pro 9500 II as I see them on the screen. But, on the Pro 10, they're way off. Aqua now looks blue, neon green is printing a dark kelly green, red looks darker, etc. I'm using Epson Prestation Paper (only coated thin paper I've found) on the 9500, I would use the setting for Matte Paper standard quality with excellent results. Tried Matte Paper and also plain paper settings on the pro 10 and can't get them to look right.
I know the colors were fine before, never had a customer complain, but now nothing matches. I've upgraded printers before and there's always subtle differences in the print quality but this isn't even close.
Any suggestions? FYI, I'm using Paint Shop Pro X6 to print.
10-04-2014 02:59 PM
I've seen that already too. Everything keeps going back to monitor calabration. But, everything was printing fine before I changed the printer.
I can accept some variation, but the colors look correct on every monitor (and my old printer), but not the Pro 10. When I'm printing a color called "lime" I don't expect it to look kelly green in print. It looks fine onscreen, but regardless of that, it shouldn't print as a dark green. Likewise when I print aqua, I don't expect it to look like a medium to dark blue.
10-30-2014 03:32 PM
JenL256,
Were you able to find a solution for this? I'm having the EXACT SAME problem now that I've upgraded to the Pro-100. The color variations you are describing are the exact same issues I'm having... lime coming out kelly green... bright reds coming out dull. Nothing has changed except upgrading to the Pro-100. Every printer I've had before was MUCH closer in colors and these aren't even remotely close. Very dull and dark. I also tried calling support and they weren't any help 😞 they only had me set it back to default and when that didn't work told me "colors will vary between printers".
Any help you can provide that may have worked for you would be greatly appreciated!!
11-04-2014 10:48 AM
I have three of these printers in this line. The 9000, 9500 II amd the Pro-100. Not a Pro-10, however.
They all printed differently but after a little tinkering with the settings, they all did very well. They are great printers.
First off you must not let the printer set anything. Turn off every bit off control it has. You can do this with the Canon My Printer under the Printer Settings tab. Do you know how? I will guess, yes, for now but if you don't get back to me.
Second, you need to have photo editor handle all settings and color matching. You know how to do this?
And lastly, it is essential you get some settings on your monitor that somewhat matches what the printer is printing. Your printer may be doing exactly what you are telling it to do and you have no idea it is. Because your monitor is off. If you don't do this step, you can forget the other steps. However, there are only a few things that you need to be concerned with. You don't need any fancy extra add-ons to do this.
But you must get the grey-scale very close. You need to get the brightness very close and you need the contrast very close.
After you do these things you can make adjustments to your prints by just looking at your screen. Because you know the monitor and printer are on the same level. One more point, you can NOT get a printer to print every color exactly the way you saw it. It isn't possibile as all colors and adjustment effect all others. My goal is to get the skin tones right. That is what people notice.
For instance, I know my newest Pro-100 tends to print darker than what I see on the monitor. So, I automatically know to set it's prints one stop brighter in Photoshop, in my case. It also prints with a slightly warn tone. Most of the time, with protraits especially, this if OK but sometimes it is not. In that case I adjust the "temp" setting slightly cooler in PS.
Make sure you have the correct ICC profiles and you are using Canon brand ink and paper untill you get good with the printer. Very, very important, otherwise you don't know if the printer is doing exactly what you are telling it to or not.
12-04-2014 06:41 PM
12-04-2014 07:07 PM
12-04-2014 07:18 PM
12-04-2014 08:29 PM
I have no experience with Paint Shop Pro but it is probably the problem. If you already did what I told you to do, it is the only thing left. If, however, you did not do exactly what I explained you are going to have issues. And if you didn't I can't help you and you are going to have poor prints.
An investment in Photoshop Elements is my next option. It will print very similar to the full blown Photoshop.
You must turn off printer color management and can do so with the Canon software.
Re-read my post and make sure you have done completed everything. Good luck.
12-05-2014 10:50 AM
12-05-2014 11:11 AM
I hate to keep reffering to this but did you do all I asked you? You didn't actually confirm that.
You have all Canon ink and paper and profiles? Set color to 'none' in the printer? The monitor settings? Everything?
If one of these is missing or not done, you are not going to be successful.
If you have done all I asked, the problem is in your editor.
12-05-2014 11:20 AM
