09-28-2025 06:01 PM
Greetings all, I am going to print a book with photos and lots of text, on double-sided matte paper. Sending from InDesign to the printer, and printing on Red River Premium Matte 50-lb paper. I know because of the "sandpapery" personality of the surface that facing pages will eventually transfer ink through pressure and rubbing, from a dark picture on one page to the unprinted white paper on the opposite page. One way to minimize this is to use Premier spray lacquer to seal the surface after printing, but this requires mutliple coats. Just now, it occurred to me that in the print dialogue, if I tell the printer I am using a paper that is not "matte photo" but instead Luster or Semi-gloss, will that invoke the clear coating and mean that whatever ink is laid down on the sheets will be sealed afterward by the Auto setting? Doing this would save me an *enormous* amount of time and expense in spraying multiple coats of lacquer on each side of every sheet. And a related question: which paper setting would be closer to the amount of ink normally used by printer on matte paper . . . luster or semi-gloss? Thanks, Bruce
09-29-2025 01:01 AM
"Invoke the clear coating"? What does that mean? A printer does not put any coating on a print to make it shiny. The surface gloss comes from the paper's surface. You have to apply a clear coating. And a paper surface being "sandpapery"? I can't picture that. Doesn't sound like a matte photo paper. Canon's matte photo paper is quite smooth. It just has no lustre.
09-29-2025 10:08 AM
You clearly do not have a PRO-1000/1100 or you would not be making such incorrect statements. And on a microscopic level, yes, matte papers do have a sandpapery texture when compared to glossy papers.
09-29-2025 11:45 AM
"On a microscopic level....."? Wow. Even gloss papers have texture on a microscopic level.
09-30-2025 11:45 PM - edited 09-30-2025 11:47 PM
I checked out the specs and manual for your printer. Nowhere does it say anything about applying a clear coating.
What are you talking about? It appears you are misinterpreting something in the advertising.
10-01-2025 10:02 AM
As I said before, you must not own a PRO-1000. I, on the other hand, do own one. The coating to which I refer is Chroma Optimizer, which has its own cartridge along with all the colors. There are two choices for using this in the Advanced Paper Settings dialogue: asking for Auto (which seems to put coating down only where there is ink deposited) or asking for Overall (which puts the C.O. over the entire sheet).
10-01-2025 05:27 PM
Should have said that before. Good luck.
