11-09-2022 02:24 PM - last edited on 08-15-2023 08:02 AM by Danny
My print dialogue box doesn’t show all the options. I don’t have any color options and the Quality Media setting is different - it doesn’t have media type listed. The show details box is activated. I’m using a Mac book pro running Monterey 12.6 and printing from Light Room Classic. I think I’m missing a setting somewhere that needs to be changed. Any help would be greatly appreciated.
11-10-2022 03:19 PM
Hi sueb500! Thanks for posting in the Canon Community Forum. I see that you do not have access to some of the print settings (color and media) for your imagePROGRAF PRO-300.
There may be an issue with the CUPS Printer Driver that is installed on your computer. It’s also possible that your computer is not using the CUPS Printer driver properly. For that reason, I recommend reinstalling the driver, deleting the printer, and adding a new copy.
To install/reinstall the driver, please follow these instructions:
When the driver has finished installing, please delete the printer by doing the following:
When the printer is no longer listed, please add a new copy using these instructions:
After you follow these steps, you should have all the print options available when you go to print.
Please post again should you continue to need help.
I hope this information helps. Thanks again.
01-01-2024 03:58 PM
RESOLVED after more sleuthing. Found this resolution:
https://support.usa.canon.com/kb/index?page=content&id=ART180492
11-10-2022 03:19 PM
11-11-2022 01:50 PM
Thank you so much!!!!! It worked!!!!!!
01-01-2024 03:51 PM
I am on a Macbook Pro M1 running Sanoma 14.1.1. Having the following issue:
I updated the print driver to ver 26.10. After updating, some printer options went away (like color management), so I removed my printer as you suggested above, but the issue remains.
When I uninstall/reinstall the printer, it uses an Airprint driver ver 3.0. I don't see how to select another driver.
Thanks for your help!
01-01-2024 03:58 PM
08-15-2023 07:10 AM
I have the same problem that I have not ticed until trying to use a non-Canon paper. Items are missing from LCD panel menus on the printer, I am running OS Ventura, Lightroom Classic.
Thanks
08-17-2023 12:46 PM
Go into printers and scanners on your Mac and remove the printer. Once that is done, add the printer back and make sure AirPrint is not select for the driver.
Once the printer is added back on, check for the printer or Lightroom again. If you are missing paper profiles from third parties, then click HERE and you will want to download/install the PRO-300 ICC Profile for Supporting the Other Companies file.
