Reply
Highlighted
New Contributor
Help with Pro 10
I am having several issues with my Pro 10 and cannot find any self help. They may be related.
Platform: Mac OS 10.15.3
Software:  Lightroom
1.  Printer worked perfet on first print.  Now when a print is sent it pulls a sheet from the input tray, through the printer, and to the output tray without printing.  This takes about 3 seconds.  The printer dialog box clears the job as if the print was made.
2.  I have a "Marker Supply Low" dialog with yellow caution icon.  Two colors are low but not out.  Normally I would get a low ink warning but I don't rememer it being worderd as Marker Supply.  Is this the same thing as ink or something else?
Aaron
Highlighted
Honored Contributor
Re: Help with Pro 10
Relative to the "Marker Supply Low", this is from Apple forum:
https://discussions.apple.com/thread/251047451
Relative to your paper feed issue, do you have the latest Canon driver - 16.40.1.0?
https://www.usa.canon.com/internet/portal/us/home/support/details/professional-large-format-printers...
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Highlighted
New Contributor
Driver version 2.0
Highlighted
Honored Contributor
I'm not sure what that is. No one has ever posted that window before.
If you want to try this I recommend:
1. Download 16.40.1.0 from the site I linked to.
2. Delete your printer in System Preferences->Printers & Scanners
3. Select "+" button to add printer.
4. Wait for Canon IJ Series to appear - it could take several minutes.
5. When it appears select it and the printer will be installed.
Highlighted
New Contributor
Ok, instruction followed and reinstalled printer.
Still feeds a sheet through the rear tray without printing and clears the print que.  When using the manual feed, it will not recognize paper in the tray.
Highlighted
New Contributor
I got it figured out.  I wouldn't have if you hadn't showed me the proper driver.
Thanks,
Highlighted
Honored Contributor
[ Edited ]
Then my recommendation is to call Canon at 1-800-OK-CANON.
We crossed while typing.
Glad it worked out for you.
powered by Lithium
