04-05-2020 07:09 PM - edited 04-05-2020 07:12 PM
When I upgraded to Catalina back in November it screwed up my colors and created a magenta cast on my prints. Similar to what this user reported (I'm using the same brand as them, too!). https://community.usa.canon.com/t5/Professional-Photo-Printers/Pixma-Pro-100-Magenta-Cast-on-Mac-Cat...
After several hours of banging my head against the wall I discovered my driver was outdated. Once I updated that my problems were solved and I was back to printing accurate colors.
Fast forward to today, I'm again seeing some color shifts. Specifically, the colors are not as accurate as they have been before. I have the latest version of the firmware and driver (which is same as the last time I updated). In the last week I updated Catalina with some updates so I'm now on 10.15.4.
Is anyone else having this issue?
Here's what I've done so far to troubleshoot:
- I checked my firmware and driver against the Canon site. I'm current.
- Lightroom and Photoshop are both current.
- I deleted and added the printer again. It's using the Canon software.
- I've even downloaded the paper profiles again and overwritten the previous versions (there was no difference)
- I've checked and double-checked my settings in Lr and Ps. (attached for reference)
Any other ideas? Thanks in advance.
Print dialog settings...
Lightroom print settings...
Photoshop print settings...
05-28-2020 11:05 AM - edited 05-28-2020 11:08 AM
Thanks again John,
1. I've used LR print module for printing. I've also tried to print it using Canon Print Studio Pro plugin in LR. It didn't make a different.
2. Paper is Canon photo paper pro luster 8.5x11
3. I've tried both print managed and Canon PRO-100 <LU> ½ pro paper pro luster ICC profile. They both produced similar results.
BTW, my monitor was just calibibrated using xrite x1studio before the printings.
05-28-2020 11:21 AM
Monitor calibration won't affect the test image as long as you aren't making any adjustments in the software.
The grayscale ball things (I have not figured out what they are) also look yo have a pinkish color cast as well.
Three more thoughts
1. Verify that all the clear tape is removed from the top of the cartridges. There is a tiny vent hole on top and if restricted ink can't flow properly.
2. Recheck proper seating of print head and cartridges. If these steps don't help
3. Run a cleaning cycle.
05-28-2020 11:59 AM
Yeah, I think the grayscale ball had a slight pink tint as well.
1. You meant the yellow/orange clear tape? yes, I did this yesterday after seeing some suggestion from one of the posts.
2. I'm now out of gray ink after all these test prints. I need to order a new set and will let you know if the new ink set help.
thanks again for your help.
05-28-2020 01:13 PM
How many prints have you made? If you run a nozzle check it will tell you.
That seems awfully quick to use up gray ink. What are the levels of the other inks?
05-28-2020 01:34 PM - edited 05-28-2020 01:38 PM
I printed about 30 on 8.5x11 test prints on other photos which has more gray colors. I did 3 cleanning cycles and 2 deep cleaning cycles, 2 nozzle checks. This is a brand new printer so it consumed some initial inks to setup as well. LGrey is about 20%, other colors has 40-70% left.
05-28-2020 01:41 PM
We recommend reaching out to support for one-on-one help with this. They'll be able to help you nail down what's going on, and help you determine if there's a fault with the printer. At their descretion, they may also be able to send you a replacement cartridge, depending on what's going on. You'll want to log into your My Canon Account for your personalized support options - here's a shortcut: canon.us/account
05-28-2020 02:34 PM
thank you John, I called the canon technical support but they said I need to replace the ink first to resolve the out of ink error before they can help trouble shoot. I will provide an update once I get the ink replaced.
06-02-2020 03:07 PM - edited 06-02-2020 04:34 PM
My issue with magenta cast was resolved! I called Canon technical support yesterday and they diagnosed it to the print head issue. They sent me a new print head and I can happily confirm that the new print head fixed my magenta cast issue.
06-02-2020 04:16 PM
Gfeat news.
And thank you for posting the resolution. It may help others.
06-02-2020 09:13 AM
Yes and it's driving me crazy!
I did the same thing. I redownloaded the drivers and still get a color shift. Apple upgraded to 10.15.5 but the problem wasn't solved.
I hope this gets fixed soon!
Good luck.
