04-15-2020 04:31 AM
Hi all,
I hope someone can help.
Last week my canon professional print and layout software just stopped sending my images to print. I keep getting the error " Error - please check the printer's operational panel or remote UI" in the print job screen (see image below).
Lightroom & Photoshop are able to send to print but the results are very different.
I have reset & re-installed everything. All software and drivers are up to date.
I'm running iMac with the latest Catilna software. Like I said before, it was all running fine last week.
Anyone expereinced the same issue?
02-23-2021 03:05 PM - edited 02-23-2021 03:06 PM
Hi eclubfoundation and KristinMcCarrol,
Please contact technical support via phone for further assistance. There is NO charge for this call. Please dial 1-800-423-2366, Monday-Friday 8:00 am to 8:00 pm Eastern Time, excluding holidays.
02-20-2021 05:32 PM
Did anyone find a solution for this error code? I just purchased a PRO-4100 and haven't been able to print anything from Professional Print and Layout. I've uninstalled and re-installed all software.
03-02-2021 09:19 AM
Same here. I am using a PRO-300, which prints fine from Capture One 21. I can also send it a test print from Windows 10. It's connected via WiFi, which is working (the printer has even downloaded and installed updates twice). So the problem doesn't seem to be the WiFi connection, at least from what I can see. From the Professional Print & Layout app I get a "ERR_CONNECTION_REFUSED". This only happens from Professional Print & Layout. It worked fine when I first started using the PRO-300, and then stopped about three weeks ago.
I am running Windows 10 Home on a Dell Inspiron 5675.
For the record, I have called Support three times. They might be able to help if they would answer the phone.
06-19-2021 05:54 AM
I have used this software for a while and I know its pitfalls. I have a printer registered, I send the image, It says sending then just disappears. It was working fine last week, I've tried printing the same image that printed fine last week just to make sure there were no file errors. I've tried to install/reinstall. Switch on/off. Manually entered Ip4. Nothing. I've found my IP in settings, but the printer is altering one number and I can't correct just the IP. so frustrating as I know the solution but I can't fix it. Mac using Big Sur and have the current PPL.
08-13-2021 02:59 PM
Hello Whitehouse,
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance.
For a more immediate resolution to your issue, you can contact our phone support team at 1-800-652-2666. Our agents would be happy to help.
09-17-2021 11:20 PM
I'm on a Win 10 with Canon Pro-300 using wired connection. I had to add my printer back in to Professional Print and Layout by going to Stored Settings (on the right), then Printer, then Add Printer and search and used an IP address instead of the Mac address. Then it worked fine for me. It sure seems like the error message could be more useful like "Can't find the printer" or something. I hope this helps someone.
07-16-2023 03:11 PM - edited 07-16-2023 03:13 PM
If anyone comes back here with a similar issue, I had to fix this slightly differently. I'm on a Mac btw.
My issues stemmed from the fact that I initially installed the printer using Wi-Fi, then switched to wired LAN.
Initially, the printer had a particular IP that I had to switch to the wired IP - and I thought that fixed it.
But the issue became I could print a single photo, then the Job Manager would show the same error as posted in JustJamesK's image above.
I installed, uninstalled the printer and the applications multiple times. I force quit the applications and restarted. I had some random success printing two photos in a row, but most of the time it would fail printing a second photo.
Rebooting the machine would allow me to print one photo.
What seems to have fixed it for me ( please dear god let this fix stick ) was choosing the printer via ( what I think is the ) mac address, not the IP.
My suspicion is the software - somehow, somewhere - still see's my old IP address from the initial installation.
