04-15-2020 04:31 AM
Hi all,
I hope someone can help.
Last week my canon professional print and layout software just stopped sending my images to print. I keep getting the error " Error - please check the printer's operational panel or remote UI" in the print job screen (see image below).
Lightroom & Photoshop are able to send to print but the results are very different.
I have reset & re-installed everything. All software and drivers are up to date.
I'm running iMac with the latest Catilna software. Like I said before, it was all running fine last week.
Anyone expereinced the same issue?
04-15-2020 08:10 AM
Thank you for your inquiry, and welcome to the Canon Forums.
We appreciate your participation, however, for the community to best assist you can you provide us with the following information:
If you are in the USA and need immediate assistance please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to help! If you live outside the United States, to go: https://global.canon and select your country or region for your support needs.
03-02-2021 11:49 AM
I had the same issue and after calling Canon support and walking through it the tech found the issue. My ISP swapped out my router a few weeks ago and the IP address space on my network changed. PPL was still trying to send using the old IP address of the printer. So when it adds the printer, whatever IP address it has sticks so you have to manually add it again using the new one.
Took a while to get them on the line but he nailed it first try. Good job Canon tech support. I hate that I didn't notice that but either way, it's fixed. Hopefully this helps someone else.
03-04-2021 10:56 AM
Thanks for replying, ncsamiam. It does look as though PPL is looking to the wrong IP address. It won't allow me to remove the current printer, or add a new one however. Nothing's changed on my system that I'm aware of, so this is kind of perplexing.
So I'll have to keep trying to get through to someone at the support number. I tried again this morning, however had to give up after almost 30 minutes of listening to 60s era mellow jazz hold music. Will try again later.
03-04-2021 11:21 AM
Yes it won't allow you to remove all the printers in the list. When I told it to add printer, I selected "Auto" and it immediately showed it to me, albiet with a different name, and when the new entry was added I was then able to delete the old entry. If you change from Auto you can give it a specific IP address to look for it. Maybe try that if you haven't already. And good luck.. I put them on hold and just left the speaker phone on while I worked on other stuff. Odd music selection, I must say. 🙂
03-04-2021 02:18 PM
I finally got through to the support folks! Had to block my calendar to allow time for it, but success! Didn't even have to listen to the music for very long.
So PPL is once again working, after finding the correct IP for the printer, which was somehow different than when I originally installed the software. I may never know what happened, but at least now I know how to correct the problem.
07-30-2021 06:13 AM
Would you mind sharing what process they advised you in order to fix this?
11-04-2020 08:54 PM
Have you had any resolve? I have this problem too and can't figure out what is wrong.
09-16-2022 03:21 PM
Hi.
I faced the same issue. What is happening is that the Software Professional Print and Lay Out (PPLO) is looking for the old printer which you can see in the tab Printer (just below stored settings on the right hand side). If you click on the printer tab, you will see two options -"Add Printer" and "Delete Printer". Press "Add printer" and select your Cannon Printer once again. Once it is registered, Delete the old one. You should be able to use PPLO software.
The issue frustrated for a long time. Hope you too can resolve the issue with above steps.
Regards
12-22-2020 02:03 PM
