10-22-2020 03:05 PM - last edited on 01-03-2024 09:05 AM by Danny
When I try to print on this paper on my Canon Pixma Pro 100 while using their paper profile and setting "Other fine art paper" it refuses to print saying: with the media type you have selected you need to set the paper size to one for art paper with margins.
The only way I can get it to print is to set "Matt paper" in the driver.
10-22-2020 03:30 PM
Welcome to the forum.
If you want to use a fine art ICC profile amd media type you need to select a fine art paper size.
This screenshot is from a Windows computer.
If you are on a Mac and don't see a similar dropdown be sure you aren't using the AirPrint version of the printer.
10-31-2020 09:35 AM
Thank you for the reply. I talked to a Canon rep about this and he told me the reason for this is that if the printer was allowed to print close to the edges the paper could curl and cause a jam.
10-31-2020 10:56 AM - edited 10-31-2020 10:57 AM
That is correct.
If you go into the printer driver and select "Prevent head abrasion" you can successfully print using a non-fine art paper selection.
Depending on the paper surface generally select Matte Photo Paper or Photo Paper Pro Luster using the custom ICC profile for the third party paper.
01-01-2024 07:07 PM
I had the same problem. I had the paper settings wrong. I had also ran out of Chroma. When I replaced ink, I had forgotten that I Had A3+ paper, not A3. When I replaced the ink and changed the paper settings it printed perfectly.
