10-01-2021 04:00 PM
Since I upgraded Big Sur, My lightroom CC will not load Print Studio Pro. It is installed and shows in addin manager. It is accessable in the plug in extras and appears to start but then no window. I have tried re down loading and re installing
Any help would be great
10-26-2021 04:53 AM
Big Sur 11.6.1 resolved the issue, now Print Studio Pro works as expected...
10-01-2021 06:57 PM
Welcome to the forum.
Problem with the macOS update. Do not know of any fix right now.
10-03-2021 11:32 AM
I'm having this same problem but with Canon Digital Photo Professional 4.15.0 not loading Print Studio Pro. DPP4 simply locks up and I have to Force Quit. This is after upgrading to Big Sur 11.6. The Plug-in Printing Option shows but doesn't load. I, too, have tried re-installing DPP4 4.15.0 and I've also reverting to DPP4 4.14, bu no luck. It's a shame because I really like Print Studio Pro.
10-03-2021 12:42 PM
It's a PSP problem so it affects all applications that can use PSP.
10-03-2021 01:56 PM
Thanks for the replies, John. I guess it's just a matter of waiting for an update to Print Studio Pro that fixes the issue.
~Kris
10-05-2021 10:00 PM
Hi!
I have the same issue with Photoshop not loading Studio pro 2.2.5 On Big Sur 11.6.
Print Studio just doesn't load even if it shows in the Plug in pannel for Photoshop. Photoshop stops responding each time I try to load Print Studio.
Any idea on when this will be fixed or a new version uploaded? I use this to print for my small business and this is really hindering my order process.
Please please help!!
10-26-2021 04:53 AM
10-28-2021 03:36 PM
Thank you so much for your post. Print Studio Pro is niw working on Photoshop Elements with the update you described.
01-11-2022 12:05 PM
That is fine for Big Sur. However, any comments regarding Monterey (OS 12.1) which is the latest upgrade?
01-11-2022 12:09 PM
Works for me on Monterey 12.1 (M1 Max MBP 2021 - but only in Rosetta - and Intel MBP 2020)
