Hello, we have an imageRUNNER Advance C256i in our office, we weren't able to succesfully connect the printer to a wired router, so we were trying to setup a wireless LAN connection and given we weren't very familiar with the options we kinda soft lo...
Hello. I am looking at digital book press printers. Such as PRESS C10010VP. They are quite expensive. But I see they are inkjet. I was shocked when I discovered this. Isn't inkjet print fuzzy and low quality? Doesn't the print also completely disinte...
Since about 4 days ago a CPU that had no issue with printing is now producing NG(#0853) in the print log Windows 10 (build 19401) should be the most current versionNetwork printing to an iR 2535 Standard TCP/IP port 9100Have tried both UFR II drivers...
We do have problems with our Pixma G3411, it prints with white horisontal lines, but only in the black.This is a normal document.This is what we have tried. " more than once with no change at all"1. running from the canon IJ Printer assistant toolCle...
Hello all,Can anyone tell me if printing envelopes on a PIXMA TS3522 is possible? Ive created a template on Google docs for envelopes but the paper tray isn't wide enough to accept the standard size envelope when placed horzontally. It will accept ...
Just purchased a TS9520 for the purpose of printing on DVD's. Saved my first template but nowhere could I find where the template went to. In the User Manual, in the instructions for printing on DVD's, there is just a button that says "SAVE" with n...
How to scan a document and send to file to Lenovo with Windows 11?
I have had great luck with my MF642Cdw Wireless Color Laser printer....was working great, then out of the blue every print is full of blotches...like toner is leaking onto the transfer belt. None of the internal cleaning routines are working (i run ...
My K (black) toner was out so I replaced it with legit Canon 045H black toner cartridge. I am still getting the error about continuing to print quality not guaranteed. When I run a consumables status report, it says 0% level on black and the cartridg...
ImageCLASS Mf733Cdw puts black marks near right side (portrait) at regular spacing. The marks are short faint black lines, about 1/2 inch in length, spaced at regular intervals of about 2.125 inches. There are two columns of marks (portrait perspec...
The original color cartridge ran out and I replaced it with a Canon brand 276XL. I'm getting error codes 5 and 9 but the cartridge is installed correctly [this is my 3rd Canon inkjet[ and I can color copy and scan. But when I go to print I get error ...
My new MacBook can install the print driver of imageCLASS MF4880dw and work well . However, after installing the scanning program, I cannot connect to the imageCLASS MF4880dw.I got the driver from the link.Both the printer driver and scanner driver ...
When I print from our laptop I get an error message (little orange triangle lights up) then I push it once and it prints fine. What am I doing wrong?
Hi I have an ImageCLASS MF753cdw machine that I am trying to setup the scan to email settings. I need to provide the machine with my SMTP settings. The user guide advises to use the Remote UI > Settings/Registration > Network Settings. However, when...
User | Likes Count |
2 | |
2 | |
1 | |
1 | |
1 |
