i-SENSYS MF633Cdw Software Installation Requires Admin Rights
dannering
When trying to install the driver for the Canon MF-633 laser printer & scanner, I am prompted by
"To install the software, you must log on as a member of the Administrators group."
I am the administrator and the only user on for the computer in question - what is the solution for this?
Thanks in advance for a solution,
Daniel
3 REPLIES 3
normadel
Are you sure yo are an Administrator on this computer? Who initially installed the operating system, or was the first person to use it if it came with the OS already on it?? The person who did either one would be an Administrator. If they created a user account for you, they may not have made it an Administrator-level user.
Welcome,
"To install the software, you must log on as a member of the Administrators group"
We know this is a error in Windows OS.  In additions to confirming @normadels question, can you tell us which version and built of windows you are using the printer with?
Since there are multiple versions of the installers PCL/UFRII, and all are self-extracting .ZIPs, here are some additional suggestions.
Right-click on the .exe and select Run As Administrator
Rename the .exe to .zip and extract the files, run set up
Before
After
Let us know if any of these options help.
normadel
Oh yeah, I forgot about the "Run as Administrator" option on the right-click menu. I occasionally run into this myself. Sometimes a program installer doesn't want to accept that you already are an Administrator. Telling it specifically to run as Admin is required.
