PIXMA MG3620 - looking for help changing scanner settings to disable pdf
tf42345t
I'm not good at this stuff. I just want the scans to be in image, png or jpg. Really, I'd think it'd be easy here in settings:
But I can't figure it out. How do I disable pdfs?
3 REPLIES 3
ArthurJ
When you need to scan, select the photo option in IJ Scan Utility. By default it will save the scan as a jpeg. If you need to change the photo scan file type, go into settings and select photo scan. From there you can change the file type.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
Where is IJ Scan Utility? I posted a screenshot of exactly what I am seeing. I asked how to change the settings so it quits giving me pdfs and I get images. How do I do that?
Click the Windows start button, scroll down and look for a Canon Utilities folder. Open the folder and select IJ Scan Utility.
From there just select the photo option.
