[Linux] MF/LBP Network Setup Tool Ver.2.31 Is Obselete
X0X0X069
Hello, [Linux] MF/LBP Network Setup Tool Ver.2.31 is obsolete; and I cannot setup imageCLASS LBP6230dw to connect via WiFi. \
The Remote UI doesn't support WiFi setup neither.
I cannot install the utility on Debian 11.
Do you  have an upgraded utility I can use?
Thanx
$ sudo apt install ./cnnst_2.31-1_amd64.deb
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'cnnst' instead of './cnnst_2.31-1_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cnnst : Depends: libgnome-keyring0 (>= 0.6.0) but it is not installable
0 REPLIES 0
