01-16-2016 05:38 PM - last edited on 12-17-2022 08:56 AM by Danny
Hi everyone
I've been trying to set my printer so that I'm able to print on glossy paper in A4 size. But my printer won't allow me to do this as it says the size doesn't match the paper type. I have tried just using regular paper settings but when I do this the black ink smudges and I am told when set to glossy paper the black ink won't smudge. Does anyone know how I can make my printer understand that I'm using an A4 piece of glossy paper and not regular sized photo paper? Sorry if this question seems stupid.
I'm using a Pixma MG2550
Thanks
08-03-2016 06:07 AM
Found this elsewhere on the forum. Hope it helps.
12-16-2015 08:55 AM
Hello.
The printer will feed from the upper tray when a smaller size has been sent to the printer. Check the settings in your program to make sure that the correct size has been specified before printing.
If you continue to have difficulties, find more help at Contact Us.
08-03-2016 07:32 AM
Thanks. With a bit of fiddling I manged to get it to print on glossy photo paper but only on one side. It jammed when I tried to print on both sides! Progress of a sort.
Best regards,
Chris
12-13-2017 10:35 AM
Hi Every one,
I own a Canon E3170 PIXMA 3in one inkjet printer, I was trying to set up print on a glossy A4 paper - but the machine dosn't allow to select it - when #Canon will address this issue?
12-13-2017 10:48 AM
Hi imraghu79!
Welcome to The Canon Community, and thank you for your post!
We appreciate your participation, however we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market, and the printer you've mentioned is a model that is not supported by Canon USA.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
01-04-2018 10:23 PM
It would appear that the MG 2560 cannot print A4 colour prints. It is outside the settings allowed.
I spent two hours being "helped" by a sevice person from canon call centre. I came away convinced of two things...the printer cannot print colour phots using A4. and secondly the service person hadn't the necessary knowledge of the printer and wasted my time...BUT in a nice polite way without admitting the lack of real MG2560 printer specifications and abilities.
I tried setting to print for plain paper A4 (not colour photo size) and printing colour but the result was extremely washy indicating that it was actually assuming it was plain paper.
Either get used to letter sized priints or get a new printer. I will hang in with the MG2560 because it is the simplest cheapest printer scanner on the market at this date! I paid $18 AUD !!! great price..adequate printer! Using self fill colours! Can't beat it!
01-04-2018 10:26 PM
10-15-2019 12:03 PM
10-02-2020 01:42 PM
I'm not if this will universally work, but I was able to get around this limitation by adding a "copy" of the printer. The copy of my TS 300 has a limited "printer preferences" menu where I can choose (and actually print) Letter + Glossy. I did this on windows by going to "Printer and Scanners" and connecting to my printer which was already connected.
08-27-2021 10:58 AM
08-30-2021 10:48 AM
No problem using Linux OS ! I just printed on A4 sheet and glossy paper
