04-16-2014 11:12 AM
I have a new mx459 printer/scanner. All scanned images show what seems to be a background moire pattern. Going to a high resolution doesn't help much. Also the scan speed seems unusually fast. I've tried various image settings but the problem is always there. I'm out of ideas...
04-16-2014 11:17 AM
Hi barrybud!
So that the Community can help you better, we will need to know any error messages you're seeing (either on your printer or on the computer), and the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your printer (USB or networked via WiFi or Ethernet).
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks and have a great day!
04-16-2014 11:50 AM
A little more info on the problem... There are no error messages. Op system is windows 8.1. Scanner is connected via Wifi.
06-28-2014 06:19 PM
Hello barrybud,
Does the issue occur when making a copy?
06-30-2014 12:42 PM
The moire pattern is visable in the scanned result (jpg file) or when printed.
