04-22-2013 12:13 PM
I simply want to receive a fax! I would be content even if I had to do it manually, i.e., temporarily switch phone line from phone to printer. When I attempt to set it up and call my number from another phone, it appears to pick up the call, but I'm not certain. It immediately lights up "Fax Memory" and I get an error code of 5001. It's possible my settings are correct and I'm simply attempting to reach my fax via a voice line, but without actually hearing any tones, I can't be sure. If it is set up to not print but go to some memory, I haven't figured out those settings.
Can anyone help, please?
Thank you!
Patty K
04-24-2013 04:34 PM
Hi pattyk999,
the 5001 might not be an error code, this could be the number it's assigning to the received fax. The best way to test it would be to try sending a fax to it rather than using your voice line. If you receive an error from the fax machine you are using to send, ew can try and troubleshoot it from that point.
