09-24-2013 01:18 PM
Hi, has anyone else had issue with fax detect settings on these units? I set it up to automatically detect which it will do, unfortunately it also squeals upon every single call you take about ten seconds into it....I either can bear with that or disable it to manual in which i miss all the faxes i get unless i notice them coming in....I also have an answering machine on this phone line just for more info. Anyone have any luck getting it set up to receive without the annoyances while talking on normal calls? Tried every different combination of setting on the device, followed the instructions in the manual and it still does the squealing when i take calls unless i put it on manual reception...
09-26-2013 09:16 PM
Hello mansfileddairy,
Setting the User-Friendly RX setting of the printer to ON may resolve the issue you are experiencing. To do this, please follow these steps:
Make sure that the machine is turned on.
Press the FAX button. The Fax standby screen is displayed.
Press the Menu button. The FAX menu screen is displayed.
Use the button to select Receive mode set, then press the OK button.
Use the button to select the TEL PRIORITY receive mode, then press the OK button. The confirmation screen asking whether to make advanced settings is displayed.
Use the button to select Yes, then press the OK button.
Use the button to select USER FRIENDLY RX, then press the OK button.
Use the button to specify the ON setting, then press the OK button. The LCD returns to the Fax standby screen after you finish specifying all settings.
Hope this helps!
