04-09-2013 12:18 PM
Canoon mx882
error message u052
printer and scanner have worked great. Thought i should do some maintence since in 3 years i had never done it.
cleaned roller
tested ink heads
everything ok
thgen turned printer off last night
woke up this morning and get the error message.
ughh
04-12-2013 10:27 PM
Hi ddodds,
This error indicates that an internal error has occurred which may be resolved by resetting the printer. Please follow these steps for isolating and resetting the printer:
1. Open the printer's front cover, and then open and close the print head lock lever (do not remove the print head).
2. Make sure all ink tanks are seated properly.
3. Make sure all packing materials have been removed.
4. Make sure no paper is jammed in the printer.
5. Disconnect the printer cable from the printer.
6. Close the front cover and turn the printer off.
7. Unplug the printer from the power source, and then plug it back in after five minutes.
8. Power on the printer.
If the error returns, the printer will require service options. To hear about your service options, please click the following link. Contact Us.
05-18-2015 11:08 AM
Mine too !
I was in the middle of printing. It printed two pages, then beeped. On the screen, U052. Install the correct print head. I did when I bought this printer. I loved this printer, now it is junk. It was my favorite printer. No more. I had extra ink too. It's going in the trash also. I want no one to have any connection with this printer. Thanks Canon. Thousands of people have this same problem and don't say anything about it. You should take some responsibility for your mistake. At least give us a discount on the print head, if that is what the problem is. I am sure you know what the problem is.
