11-07-2012 02:11 PM - last edited on 11-07-2012 11:34 PM by Naomi
How do I fix an error code b200 on MP560
12-26-2014 02:10 PM
04-05-2015 05:32 PM
Thank you from the Russian Crimea! I get rid of replacement printer, sorry for my accent))
06-24-2015 08:07 PM
My MX850 throws the b200 error as soon as its powered on--some of the fixes I've seen won't work because the printer won't do anything once the error comes up. If the printhead is taken out, the printer gets a little further and tells me to put the printhead back in, but gives b200 as soon as I do.
Printhead has been thouroughly cleaned several times.
Does this point to a bad printhead? This multi-function printer cost about $300 new, so buying a $100 printhead makes sense, but only if that fixes the problem.
03-10-2021 06:38 PM
07-08-2015 12:45 PM
Tried everything, will get a new printer .... NOT a Canon !
08-29-2015 09:45 PM
I switched from Canon ink for the MX850 about 1/2 yr. ago. Had this printer for many years with no problems. Now today the B200 error. I've been using cheaper LD ink cartriges. Is there any possibility that using this cheaper ink ruined my printer head? Has anyone else had this experience?
09-13-2015 07:35 PM - edited 09-13-2015 08:53 PM
Thank you! This worked like a charm.
EDITED: Sorry. I'm new to the board. I thought I was replying to the individual post that helped me. I hadn't realized it would drop to the end of the thread.
bebebeck posted the following in March of 2014:
03-17-2014 11:15 AM
Here's a fix that worked for me:
1. Turn OFF Power
2. Open the print head bay (as though you were about to change inks)
3. Turn ON power
4. Wait for print carriage to start moving to the left and let it go past half way
5. Before print carriage reaches left hand side (but after going halfway across) shut the cover.
6. Leave the Printer turned on
7. Good to go.
11-27-2015 07:54 AM
12-09-2015 02:20 PM
Yah....bebebeck! Your solution totally worked....Mucho Gracias!!!!
03-06-2016 06:40 PM
