Reply
Highlighted
Occasional Contributor
Accepted Solution
does ts8120 WiFi?
Is the ts8120 designed to work with WiFi? I think "WiFi" is the correct terminology, by that I mean that is doesn't need to be connected with a USB cable
Thanks..
Highlighted
Esteemed Contributor
Re: does ts8120 WiFi?
Quick Search:
https://www.usa.canon.com/internet/portal/us/home/products/details/printers/inkjet-multifunction/ts-...
Hi-Speed USB
PictBridge (Wireless LAN)13
Wi-Fi® (Wireless LAN, 2.4 GHz, IEEE 802.11b/g/n)1
Memory Card Slot6
Bluetooth 4.0 LE (Low Energy)4
~6D2 ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100
Highlighted
@shadowsports
Yes, the article you cite clearly says that wireless is supported.
BLUETOOTH allows you to print and scan right from your smartphone or tablet
Wireless printing and scanning requires a working network with wireless 802.11b/g /n/ac or ad capability
I'd be printing from my Surface Book, which connects to my wireless network using a Netgear Blackhawk router, which does support 802.11b/g /n/ac. I'm not well versed enough in the terminolgy, but I guess that is compatible with Bluetooth. Do you know whether that is the case? Or is it something I'll need to look into? I used to use the TS8120 on the other computer in my network, but I could not get WiFi to work with the TS8120. I'm hopeful now that it was a "user error" (me) configuring the TS8120.
I'll try printing to the other printer, which is an HPOfficejet 5250 and is connected using WiFi. That will be a helpful troubleshooting step.
Thanks for your help.
Highlighted
@pwrichcreek wrote:
@shadowsports
@shadowsports
I got the TS8120 to connect on WiFi. Just follow the steps in control panel Network and Sharing. Then, there's a WiFi icon on the operations panel of the TS8120, press and it's ready to go. Now both printers are accessible from both computers.
Thanks.
powered by Lithium
