08-08-2016 09:43 PM
I have been trying over 12 hours now to solve this issue, but still not joy. I just purchased a Cannon MG2950S and tried to install it. It failed without a reason many times, both via USB and wireless. Whenever I insert the USB it registeres the scanner but fails to install the printer. I am running the self extracting .EXE downolad file as administrator, and I have tried the driver installer, and the full installer which connects to the internet. I have updated Windows, disabled all non windows startup items and disabled firewalls. Recently when attempting to install over wireless through the printers access point function I recieved the following error in a window called MP Drivers: an error occoured while files were being coppied: 0205 0049
I have tried to install this many times now, removing the previous installation each time. I have checked my group policies for printers and they are not set, I disabled it anyway to be sure. I have cleaned the registery, checked for viruses and even updated the usbprint file in the system folder (which I have reverted back again after it did not work.) I have tried adding a printer in printers and devices but it fails. It is the CannonMG2900 series drivers (in that exact format) which fails on insertion of the USB.
I am running out of options now, I have tried the device on another windows machine (Vista) and it worked fine. I have in the past installed a Cannon MG2450 which worked perfectly. Please can you assist me in solving this issue? Thanks.
08-08-2016 09:52 PM - edited 08-08-2016 09:52 PM
Hi!
Welcome to The Canon Forums, and thank you for your inquiry!
We appreciate your participation, though we need to let you know that your product seems to be a model that is not supported by our team here at Canon USA.
The Canon Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click here and select your country or region for your support needs.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
Thanks for choosing Canon!
