04-11-2020 05:02 PM - last edited on 06-27-2023 09:46 AM by Danny
My printer [Canon PIXMATS1500 series] has been working beautifully until I tried to delete a document from the print queue. The screen says "deleting" but has said that for days now, and nothing happens. I was able to cancel all the other documents, but can't get rid of this one, and can't print until it's gone. HELP
04-17-2020 04:20 PM
Hi pippaj.
If a job gets stuck on your computer, there a a couple of steps you can follow to manually remove it. You can remove the job by following the steps below.
Once the spooler service has been started again, you can close the windows and try printing something.
10-06-2021 07:40 PM
amazingly helpful and detailed for us non dos users! thanks soo much
10-26-2021 04:43 PM
MG6320 with a Dell desktop.
I have done the recommended process 4 times and my queue is definitely empty. But when I go to "Print Spooler" again and hit "Start", it shows it trying to turn on, but goes back to the choices which hav e changed to "Stop the service" and" Restart the service". I then hit the "Restart" and it shows it trying to turn on also, but it does not start again and reshows those same two buttons.
When I try to print, it still shows the Code 6000 on my printer.
Any advice? Thank you.
10-26-2021 06:07 PM
10-26-2021 06:12 PM
06-26-2023 09:00 AM
Gosh, you're amazing - thank you so much!
01-23-2024 07:59 PM
But why does this happen so often? Why do I to constantly register paper when it doesn't change? When it come time to replace my printer, I'm going back to HP. That's the solution.
