02-03-2021 10:50 AM
This printer has been bought for more than a year and is rarely used. It has only printed more
than 30 pages。
A paper jam occurred during duplex printing recently. Open the back cover and take out the
entire paper. It still prompts when printing again:1303, paper jam.
Cannot boot because of a paper jam.
The warning indicator flashes 3 times, then pauses for 2 seconds, then flashes 3 more times,
and pauses for 2 seconds. Keep
repeating
Check that there is no paper debris inside.
Open the front cover and find that the ink cartridge is stopped on the left. Press the "power
button" to turn on, the ink cartridge will move to the right, then back to the left, and then
stop.
Press the power button when power on, and the ink cartridge will move from left to right and
then from right to left. Only move once and stop on the left.
Now the printer has stopped working. A printer that feels pretty good, there will be no major
failures. Hope to get technical guidance here.
Thank you!
02-22-2021 08:19 AM - last edited on 02-22-2021 08:31 AM by Tiffany
Hi uddg811,
Please double check and perform the steps listed in the manual to clear that 1303 error with your PIXMA MG3620:
https://ij.manual.canon/ij/webmanual/ErrorCode/MG3600%20series/EN/ERR/1303.html
If the error persists, your PIXMA MG3620 would require service. You are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
To help you get up and running quickly, we also offer free standard shipping (if the order is completed by 12:30PM ET). If you would like to take part in this option, please call our Sales Department at (866) 443-8002 weekdays and Saturdays after 11 AM ET (8 AM PT) Let them know you have been working with technical support and the Canon Upgrade Program was offered.
02-04-2021 11:17 AM
One step you might have missed. Power off and disconnect from power. Reconnect and repower the device.
~CarePaks Are Worth It
02-05-2021 10:20 PM
Thank you for your reply.
When a paper jam occurred at that time, a prompt appeared on the computer: 1303, paper jam,
and there was an illustration to guide the method of removing the jammed paper. I follow the
method shown in the figure: 1. Take out the front paper (the paper to be printed), 2. Stand
the printer on its side, open the back cover from the back, and carefully remove the jammed
paper. 3. Place the printer flat and press the lower left button (color) to start the printer.
It was only when the power plug at the back suddenly fell off when the printer was standing on
its side. I noticed that the plug fits loosely with the printer socket, and it fell off with a
slight pull. Obviously this caused an "unnormal shutdown"!
I don't know what the consequences of this "abnormal shutdown" will cause. After consulting
the manual, it is explained that this "unnormal shutdown" may make the printing blurred. I
guess it may cause chaos in the motherboard program, so I plan to restore the machine to
factory settings.
he manual describes how to restore to factory settings: press and hold the "stop" button, let
it go when the power light flashes 21 times. But the operation failed: when the "stop" button
is pressed, the power light does not flash. The fault indicator light flashes 3 times as
before, pauses for 2 seconds, and then repeats.
02-20-2021 09:01 PM
I hope the technical staff of Canon community can give me suggestions. Maybe your words can save the dead
printer. Although bought more than a year, but only a few times.
@uddg811 wrote:This printer has been bought for more than a year and is rarely used. It has only printed more
than 30 pages。A paper jam occurred during duplex printing recently. Open the back cover and take out the
entire paper. It still prompts when printing again:1303, paper jam.Cannot boot because of a paper jam.
repeatingCheck that there is no paper debris inside.
stop.Press the power button when power on, and the ink cartridge will move from left to right and
then from right to left. Only move once and stop on the left.Now the printer has stopped working. A printer that feels pretty good, there will be no major
Thank you!
Thank you!
Hi uddg811,
