02-19-2020 02:54 PM
Is there any way to make them darker?
Every printer I have owned in the past has the option to make copies lighter or darker.
02-19-2020 03:14 PM
Hi toothpaste.
The Copy Intensity may be adjusted in the Copy Settings menu. More information may be found at the following link:
https://ugp01.c-ij.com/ij/webmanual/Manual/All/TR4500%20series/EN/UG/ug-044.html
Note: if the Copy Intensity is set to Automatic, the Automatic Document Feeder on top of the printer will be disabled.
02-19-2020 03:14 PM
Hi toothpaste.
03-02-2020 11:32 AM
@Darius wrote:Hi toothpaste.
Worked really well, thank you.
