03-12-2019 02:01 PM
I just installed a Canon Pixma TS 9120 printer.
When I reboot or cold boot without manually shutting down my printer using it's power button, it gives an error.
Is there a way to stop that behavior?
I had no such problem with other printers.
I am running Ubuntu.
Thanks
03-12-2019 02:14 PM
Hi, fixit7!
Thanks for reaching out!
So that the Community can help you better, we will need to know the exact error messages you're seeing, as well as the way you connect to your printer (USB or WiFi).
If you're in the United States, and this is an urgent support need, please click HERE to discover your support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
03-12-2019 03:33 PM
I connect with a usb cable.
03-13-2019 10:38 AM
Anyone ?
I also can not write to a memory card inserted into my printer.
Is it a read only system?
03-13-2019 10:42 AM
Hello!
Welcome to the Canon Forums!
The Forums aren't intended for immediate assistance. If your question is of an urgent nature, please call our US-based support team at 1-800-OK-CANON (800-652-2666) during normal business hours, or visit our support site for self-help options HERE.
If you're outside of the USA, please click HERE to find your support options.
03-15-2019 01:16 PM
Hi, fixit7!
Did you still need assistance or did you call in to tech support?
03-15-2019 02:04 PM
I was hoping for some help from here. ?
You made the printer, so I figure you are experts.
03-18-2019 01:32 PM
Hi, fixit7!,
That message will always appear after a reboot or reset on the printer. If you unplug it and don't power it down by pressing the power button that message will appear. To not have it appear, either let the printer power automatically with it's auto power feature or just press the power button.
Also if you are having issues scanning to an SD card, please click HERE for an article that covers use of a memory card.
03-18-2019 01:41 PM
Thanks. I am running Linux.
I believe those instructions apply to Windows.
03-20-2019 03:17 PM
Hi, fixit7,
Please follow these steps from the article:
Make sure that the memory card is not set.
If the memory card is set, remove it from the card slot.
Select Setup on the HOME screen.
Select Settings.
Select Device settings.
The Device settings screen is displayed.
Select Device user settings.
Select Read/write attribute.
Check message that is displayed and select OK.
Select a read/write attribute to specify setting.
Select Writable from USB PC. Even though you are using Linux but this will be the option you need to choose because Canon does not have steps for Linux.
When you select writable from USB PC, The card slot is uthen sed as the memory card drive of a computer connected to the printer via USB. Data can be written on the memory card from the computer.
